Thread: Need some help with in-laws pool
    Dec 2015
    Krugerville, TX
    23
    I don't have my test kit so the results are from a Walmart kit. Anyways. Their pool is a 10k gallon above ground pool. It seems to be a shade of green and I can hardly see the bottom. Yesterday I added some Muriatic acid because the test kit showed it to be higher than ph8.4 below are the current results from the cheap kit. Any advice?
    FC 3
    pH 7.5
    TA 40
    TH 100
    CYA 30-50
    20yr old,14k,IG,Plaster,Hayward Pro-Grid 60sqft, Hayward DE Separation tank, Hayward Multi-port Valve, Whisper-flo single speed 1.5hp pump,Hayward XL concrete pool suction vacuum, Polaris P340 (Leslies Pool model), Still working to get a test kit, Leslies Power Powder and Leslies 3" Tabs.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Need some help with in-laws pool
    Yes-----they need one of our recommended test kits and it needs to be SLAMMED per Pool School. FC is at the bare minimum for the CYA "range" you listed.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Do you have a pics of the pool? Please post them if you do. It can make figuring out issues much easier.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
