Thread: Jandy Lite2 Heater - Increase temp button broken
    Apr 2016
    South East USA
    78
    Hi,
    On my Jandy Lite2 control panel the 'increase temp' button does not work.
    I can reduce the temp, but not increase it, and all the other buttons seem to work.
    Right now the set temp is 74 and I can't make it go higher.
    I did just find that the manual states that all settings can be reset by holding the ENTER button for 7 secs. Default factory pool temp is 80 degrees. I will try this at lunchtime.
    But... anybody know if the button can be fixed without replacing the controller?
    ft.
    --- TFP Supporter status submitted ---
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Jandy Lite2 Heater - Increase temp button broken
    It's a pretty typical issue where the sun/weather kills the keypad. You will need to replace it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
