Thread: TA Test question
    Johnmarkpainter's Avatar
    Apr 2016
    Hendersonville, TN
    55
    TA Test question
    "Wipe with a damp cloth between each drop..."?
    Do we really do that? Damp with what? Pool water?
    Why is this done?
    Inquiring minds...
    Thanks
    28,000 Gallon, IG, Vinyl, SWG, Sand Filter
    Goldline Aqua Rite SWG
    Hayward Pro Series Sand Filter
    Flotec Pump
    Hayward Turbulent Flo Chamber
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TA Test question
    Doesn't really matter what it's damp with. You are trying to remove static charge.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Quote Originally Posted by Johnmarkpainter View Post
    Why is this done?
    Inquiring minds...
    Thanks
    Static electricity makes the drops hang on the tip so they end up smaller than they should be, which gives falsely high TA readings. It only seems to be a problem when the R-009 is new. A couple days ought to get rid of it. I'd just dampen the paper towel with some tap water, since the paper towels are probably within reach of the kitchen sink anyway.
    Apr 2016
    Hendersonville, TN
    55
    Excellent
    I was wondering if it was a contamination thing and that didn't make sense
