Results 1 to 16 of 16
Thread: Perfect Weekly?
    therocksaz's Avatar
    Apr 2016
    Phoenix, AZ
    10
    Perfect Weekly?
    So, a long long time ago (like a month ago) I stepped into the local pool supply looking for help getting started with my pool and the guy working the desk was nice enough, said I should get some chlorine tablets and a product called Perfect Weekly. He said this triple-action additive would help keep the pool chemistry and water nice and clear as long as I put three capfuls (about 1.5 cups) in weekly. Now, this stuff is $50/gal and I really haven't seen any mention of it around here. I feel like I've been duped. Is this really necessary?
    10,000 Gal IG Pebble Stone Pool/Spa/Water Fall Feature/Pool Cleaner Built in 1992
    Hayward DE6020 60 Sq. Ft. DE Filter
    Hayward Northstar 2HP 2-Speed Pump
    Test Kit: TF100 with Speedstir.
    38,274
    Re: Perfect Weekly?
    Oh course it is not necessary
    I would have to go Google what it even is, but I am sure it is not needed.
    You really need to be careful about the use of tablets too since we do not drain for winter or get a lot of rain around here due to the climbing CYA.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Perfect Weekly?
    well yes, they got you to buy a solar shield (chemical bubble cover) and a phosphate remover and some kind of enzyme thing... it is not going to hurt anything except your wallet, and If you have your FC at the correct level for your CYA you will not need any of that.. If you do want a solar cover to warm your pool and slow evaporation get an 8 mil cover
    You have the best weapon for great water, the TF100 and you have the speedstir, nice job! (I love that thing)
    therocksaz's Avatar
    Apr 2016
    Phoenix, AZ
    10
    Re: Perfect Weekly?
    I kinda had the feeling like I was buying something I didn't need, especially since he told me 3 capfuls each week, which, according to the directions on the bottle, is 3 times as much as recommended, but I really didn't know anything so I just went with it. So should I not use the tablets at all? I've been religiously replacing them weekly because my chlorine just goes away really fast. I typically throw in a bag of granular chlorine every Friday evening and by Wednesday the chlorine is down to like 2 ppm. I know now that that's partly because my PH was out of control (thanks TF100) but is this also relatively normal for pools in AZ?
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Re: Perfect Weekly?
    If your CYA is low, the tabs will be OK to use. If your CYA is high, you're going to compound the problem. I keep a few tabs around for my vacation week so I can meter them in and not trouble others to follow my crazy TFP method of doing things. Whoever heard of adding bleach to a pool?
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    38,274
    Re: Perfect Weekly?
    You have the best test kit. Post up some test results. Have you been monitoring your cya?
    therocksaz's Avatar
    Apr 2016
    Phoenix, AZ
    10
    Re: Perfect Weekly?
    My test results from yesterday:
    FC - 2 (still at 2 today, didn't add chlorine yesterday because I added acid late afternoon)
    CC - 0
    TC - 2
    PH - 8.2 (down to 7.6 today after adding acid according to PoolMath)
    CH - 300
    CYA - 50
    TA - 200
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: Perfect Weekly?
    The target FC level for your CYA of 50 is 6, so you want to add chlorine to get to that level and then try and maintain that. At the moment you are below the minimum FC so this needs to be dealt with ASAP.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    38,274
    Re: Perfect Weekly?
    Yup, need FC asap and you need to stop using tablets because your CYA is getting high.
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    Re: Perfect Weekly?
    You can add acid and bleach on the same day. Just add one, brush the pool then add the other and brush to mix.
    Jun 2014
    15,078
    Re: Perfect Weekly?
    therockaz, I'll go one step further .... while you already answered what your conscience was telling you at the pool store, and now you know to raise your FC, you have something else to consider.... calcium. Your pH is rising fast because your TA is exceptionally high. I'm VERY surprised your CH itself is so low for your local area. You are very fortunate... at the moment. But your high TA and pH will cause you to get scale build-up before you know it. You have a fountain, so do this .... Pool School - Lower Total Alkalinity. Lower that TA as soon as you can via this acid/aeration method of adding acid followed by aeration. Continue this until you get your TA down to something around 80-100 or so, then leave your pH around 7.6-7.7. The lower TA will help keep your pH from rising so fast, and at the same time they will help prevent scale. Remember, some of those pool store products also add calcium.
    Next time you're in the Poolmath Calculator, do me a favor ... enter ALL of your numbers in the NOW and TARGET/GOAL column. Then look at the CSI row about halfway down. I bet that CSI number is slightly over 0.6 correct? According to me it is. That puts you at risk for scale. Lower the pH to 7.7 and the TA to 100 and you'll see the CSI goes way down to about -0.15 (just below neutral). Over time, with replacement (hard) fill water, your CH is going to rise, so keeping the TA and pH at that those levels would be a good thing for you. Something to keep in mind okay.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Perfect Weekly?
    In case no one else thinks to mention this...
    If the test kit is new, the R-009 TA reagent often develops static electricity which makes the drops smaller than they should be, which makes the TA read higher than reality. The cure is to wipe the tip with a damp paper towel between drops. Just for the first couple tests.
    Jul 2013
    Fletcher, OK
    3,353
    Re: Perfect Weekly?
    You have this, you have spidy sense You knew something was up with buying that stuff and you already have the TF100 and the speedstir...
    Everyone already gave you great info, you can add liquid chlorine/bleach brush some, add muriatic acid, brush some, then check you levels and see where you are at
    You can get liquid chlorine in larger quantities and stronger 10% or 12.5% from a hasa dealer near you, http://hasapool.com/dealer_locator_hasa.php
    therocksaz's Avatar
    Apr 2016
    Phoenix, AZ
    10
    Re: Perfect Weekly?
    Okay, so I've been doing the acid/aeration deal and I successfully got my FC under control (about 5.5 last I check, I added a little more bleach just a little while ago). Here's another quick question, as I would like to eventually be able to actually use the pool, do I have to wait four hours after adding any chemicals before it's safe to swim?
    Jan 2012
    7,336
    Re: Perfect Weekly?
    LOL, no, try like 15 minutes or so
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Perfect Weekly?
    Quote Originally Posted by therocksaz View Post
    Half an hour with the pump on should be plenty. If you make a quick lap around the pool with the brush after adding, you can jump in as soon as you're done.
