Results 1 to 7 of 7
Thread: A little green above the water level.
    Oct 2015
    Winter Park, FL
    31
    There a couple of spots on the wall of my pool that gets direct sunlight for a good portion of the day, and I'm noticing some green tint in the grout, but it's above the water level line. How do I manage this and keep it from spreading into the pool? That's the only green the pool's seen in 6 months! Is this common?
    ~12,000gal. plaster, in-ground pool; Hayward cartridge filter; 1hp pump; Use Taylor 2006 kit w/ Speed Stir.
    Feb 2015
    Chandler AZ
    938
    Re: A little green above the water level.
    I'll let someone more knowledgeable answer whether it's common or not.
    You can always spray some bleach on it and scrub with an old toothbrush, then rinse with pool water. That should remove it.
    Maybe also post a full set of test results for us to look at. How does the water look overall?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yep, good plan. We get a little of that under the waterfall sometimes.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    I have an above ground pool and have to clean under the lip each year. I just walk around and spray with 50/50 bleach water then walk around with a brush then spray it all down with the hose. Good to go for another year.
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Once in a while I get some green right above the water line on the grout inside the skimmer throat. I just brush it off and raise the water level an extra half inch or so.
    Oct 2015
    Winter Park, FL
    31
    Looks like I need to get some bleach and elbow grease and get to work! Thanks!
    Feb 2015
    Chandler AZ
    938
    Uhmm..... what are you using to chlorinate the pool with? Liquid chlorine=bleach
    Gene
