Thread: Hey y'all
    May 2016
    Atlanta, GA.
    2
    Hey y'all
    Roy from Atlanta.
    New to the forum and went through some trial and error on a new to us pool when we bought a house last year.
    I tend to search and read more than ask anything as the usual stuff gets inane. I'm definitely learning a lot and not afraid to ask for help, super helpful forum, so thanks for the add.
    New to pools, 2015 bought a house that had a pool installed in 2000
    IG 35k Gal. L shaped vinyl pool. 24" sand filter. 1hp US Motor
    2 pool lights.
    Just read here that I can use liquid chlorine bleach after swearing for almost a year now about pool store chlorine prices, but currently looking into an swg system.
    38,271
    Re: Hey y'all
    Welcome to TFP!!!
    We are here when you have questions
    Please update your signature a bit:
    Hayward Vari-Flo XL is the name of the multi-valve, not the filter. What is the size/model of the filter, we do not care about the flow rating
    What brand/model of pump do you have? US is just the motor manufacturer, not the pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Hey y'all
    Welcome, Roy!
    To be sure, most of your questions will be answered in pool school, if you take the time to go through all the articles And then there's the search box, which I bet you've found.
    I just want to be the first to say,
    Jun 2014
    15,059
    Re: Hey y'all
    Hello Roy from Atlanta. Great to have you with us.
    May 2016
    Atlanta, GA.
    2
    Re: Hey y'all
    Ah, okay. Was not actually aware of that. The sand tank is about 24" wide. Unfortunately, the label has been peeled off. Same for the pump, I suppose I could/should post a pic. I'm not the most experienced at pool ownership, but I feel like the mess of tubing here could be avoided, but maybe necessary due to the plumbing requirements(?)
    I may look into plumbing a cleaner setup when I put in a swg kit.
    Thanks for the welcome.
    Welcome to TFP!!!
    2 pool lights.
