Thread: Pump Leaking between case and Motor mount
    bradntyler's Avatar
    May 2013
    Tyler, Texas
    10
    Came home to this today. Any suggestions ?? Was just starting the slam process last night. Thanks in advance
    24k, vinyl, sand, IG with 1HP Hayward Super II
    3/4 booster for polaris 3900
    Proud owner TF-100 Test Kit
    38,526
    Re: Pump Leaking between case and Motor mount
    I would suggest turning off the pump
    Hard to tell anything from that picture.
    I think you need to start pulling it apart and find where the leak is coming from. That seems too extreme to be a shaft seal unless it broke.
    Hopefully, the pump has not cracked.
    bradntyler's Avatar
    May 2013
    Tyler, Texas
    10
    It is coming from where casing and motor are bolted together. Upper screw was partially unthreaded and is now stripped to where I cannot screw back in.
    Thanks again !!
    And yes I did shut it down !!!
    38,526
    Well, might be time for a new pump if you can not screw it back together.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,833
    Looks like you blew out the O-ring sealing the front and rear shells of the pump housing. Most likely due to the stripped screw. If its a machine screw you might be out of luck. If its a coarse threaded screw you may, and I stress may, get lucky with a slightly larger diameter screw.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2014
    Roseville, CA
    345
    You might be able to have a thread insert installed. I'm not sure if that is doable, but it's worth a try. And since your pump housing is a gonner anyway, you could experiment. Larger hole, new threads if there is room.
    It's looking grim.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
