Thread: High Chlorine Level- how high is it safe to swim in?
    Dec 2014
    Cypress, Texas
    200
    Our new pool is still in start up mode, managed by the PB, it has high CYA and high FC (no surprise),but I wanted to know if it would be safe to swim in it?
    I tested the water this evening...
    FC 13
    CC 0.5
    CH 350
    TA 110
    CYA 70
    PH 7.6
    I seem to recall seeing that swimming was ok as long as the FC was below Slam level (is that correct?), but cant seem to find that information. If that is right, Slam level for CYA of 70 is 28. So are we OK?
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Jun 2014
    14,963
    Re: High Chlorine Level- how high is it safe to swim in?
    That is correct, safe below the SLAM level. Your SLAM level is 28, so you are well under that. Swim away!
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by Texas Splash View Post
    thanks for the quick reply Pat. I'm going to put on my trunks and jump in!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    10-4! We swam every day during a SLAM last summer with FC at 28 and CYA at 70. Nobody even noticed.
