Thread: Setting up UltraTemp heatpump to an EasyTouch PL4
    Jul 2015
    Abilene, TX
    6
    Folks:
    Has anyone connected an UltraTemp Heatpump to an EasyTocuh PL4 controller? Easytouch is working good. It controls my VS pump. Heatpump is connected via RS-486 connection to the com port as identified in the manual. The easytouch recognizes the heatpump is installed and the heatpump seems to register the signal from the easytouch with the "heartbeat" icon on the display panel. Problem being is that heater controls on the easytouch have no effect on the heatpump.
    I have the water temp installed and the air temp installed. What am I missing? Has anyone tried this equipment setup before?
    thanks for your help.
    Robert Hanna. Abilene, TX. 16x32 in ground plaster. 17,280 gallons. Pentair Intelliflo 3HP VS. Pentair Triton II TR-60 w/ Zeolite.
    Casey's Avatar
    SW PA
    10,423
    Re: Setting up UltraTemp heatpump to an EasyTouch PL4
    Bumping for advice.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Did you manually turn on the heat pump prior to using the ET. Is the HP wired to an Aux circuit?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
