Results 1 to 8 of 8
Thread: Hi and Help!?!
    FunInTheSun's Avatar
    May 2009
    Whiteman AFB, Missouri
    46
    Hi and Help!?!
    A little history:
    We moved into our home this past November and are looking forward to using our pool which is an above ground. The pool was installed in 2007, used for the whole summer and we assume was closed properly at the end of the 2007 season.
    The homeowners (who are military as are we) moved out in March 2008 and nothing has been done to the pool since (OUCH). We are still trying to get all the water and heavy leaves off the cover which has a significant worn area that has progressed into a hole. The more we syphon the more it seems to rain, LOL!
    We've never owned a pool and are completely clueless! I have some homework to do here reading through the site to gain knowledge. Tonight we bought a pool starter kit from Wal-Mart and we would like to start working on opening our pool as tedious as it may be.
    Any help or direction would be greatly appreciated ~ in the meantime I am off to the forums to be educated.
    Thanks so much!
    Amy
    Amy
    24' round, Vinyl, 4ft Deep AG pool 13,500g
    1 HP Hayward Pump
    Finally having Summertime FUN!!!!
    Re: Hi and Help!?!
    Welcome to TFP!
    The first step is to get as much debris out of the pool as possible and to make sure the pump and plumbing are still intact and working.
    There is lots of great material in our Pool School area.
    When you have specific questions come back and ask away, we like answering questions
    May 2009
    46
    Re: Hi and Help!?!
    Great, thanks so much! I can't wait to start tomorrow, we are optimistic that everything is in working order, fingers crossed.
    We did find a poolcare binder that came from the manufactuer but unfortunately the homeowners left it outside on the deck so it's in bad shape. I have no idea how to tell how big the pool is or what kind it is ~ any suggestions?!?
    Thanks!
    Amy
    Amy
    1 HP Hayward Pump
    May 2009
    46
    Re: Hi and Help!?!
    Okay, this will probably be overkill but I found a contract for the pool that this is what it states, not sure how to make sense of it yet:
    Bermuda King
    Swim area: 24'X24' 26'x31'O.D.
    20 MIL. Winterized Vinyl Liner
    15' Extruded Aluminum Wall Deck
    Automatic Sand Purification System
    Hayward 1 H.P. Pump and Motor
    Automatic Skimmer and Return
    Approx. 4 Ft. Depth
    Thanks!
    Amy
    Amy
    1 HP Hayward Pump
    May 2009
    46
    Re: Hi and Help!?!
    And I found this calucation for the pool:
    For a round above ground pool, the calculation is: (found on wikianswers)
    Diameter x Diameter x Depth X 5.9 = Number of Gallons
    24 x 24 x 4 x 5.9 = 13,593.6
    Gaining knowledge slowly!
    Amy
    Amy
    1 HP Hayward Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Hi and Help!?!
    Welcome Amy!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hi and Help!?!
    Hi Amy and welcome to the forum!
    You're done SLAMing when:
    Re: Hi and Help!?!
    If you haven't seen it already, you should check out my Pool Calculator, there is a link in my signature. It does lots of different calculations, including the volume calculation you found elsewhere.
