Thread: SWG Wiring Question
    Jun 2014
    Baltimore, MD
    15
    SWG Wiring Question
    Hi just bought the Circupool RJ45. I'm looking at my timer and I still need to check the voltage, but I'm pretty sure it's 220. I'm not an electrician by any means, but I feel like I know enough to get this wired. Do I need to "bond" this? I can't tell if it was already bonded or not. Here's a pic of my current setup. I believe I just need to use the same ports as the pump for the chlorinator as long as it's 220. Is that correct?
    - 18,000 Gallons, In Ground, Concrete/Plaster
    - Jandy Cartridge Filter Model #CL460, Jandy Pump Model #JHPU1.5 2 speed
    - installed in 2007
    38,283
    Re: SWG Wiring Question
    Looks like it is likely 230V to me. And yes if the SWG is setup for 230, just hook it up to the same terminals as the motor.
    There is nothing to bond as it does not look like anything is metal. Is it all more than 5' from the water?
    Jun 2014
    Baltimore, MD
    15
    Ok thanks! Yes, it's about 10-15 feet from the pool. Also, do I need to worry about the saltwater panel being exposed to sun/rain? I don't have an area with an overhang or anything.
    38,283
    Most SWG panels I have seen are designed to be outside.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    the RJ is designed to be outside, I have the SJ model and just to give you an idea.. this is what I did, bought everything from lowes and even had them cut the wood for me
