Thread: Timer needed: 2 speed 230v with freeze protection
    Mike Hawk's Avatar
    Oct 2014
    Tulsa OK
    51
    Can someone hit me up with some part numbers to google? My Google Fu is a bit lacking.
    My current Intermatic PF1102T is great right now for my single speed motor, but I'd like to upgrade to a 2 speed motor.
    2007 Gunite 15k Pump: Whisperflo Motor: B2983 2spd 2.2/0.28 SFHP Sand Filter: TR100 SWG: Aqua Rite T15 Timer: PF1102T w/ redneck SPDT toggle switch Vacuum: Milliard 19" manual / PoolCleaner 2X auto
    38,514
    Re: Timer needed: 2 speed 230v with freeze protection
    Why do you need the speed to automatically change? Usually many people are fine with just having a timer to turn it on and off and manually leaving the speed on low, expect when they need high speed for filter cleaning, etc.
    Although I see you have a PoolCleaner so that may not work too well on low speed. Mine actually does still move around a little, but I run on high for solar purposes usually.
    Mike Hawk's Avatar
    Oct 2014
    Tulsa OK
    51
    I don't know if manual switch will work for me, like you said my 2X needs a lot of suction to work. So to avoid buying a manual switch, installing it, finding out it doesn't work for my application and THEN having to buy even more stuff and more rewiring I figured I'd skip right to the dual timer solution.
    38,514
    Actually, the 2X needs about the lowest amount of flow of any suction cleaners.
    I am not sure what timers have freeze protection built in.
    Although I have read a few times, that freeze protection is not as reliable as one would hope.
