Thread: Need a Sand Filter Expert
    Jul 2015
    Aiken SC
    33
    New to the sand filter stuff and have a few questions.
    #1: What are the signs that I need to add more sand?
    #2: I know I will get some sand back in the pool, but are the signs that I to much sand back into the pool?
    #3: Approximately how many backwashing cycles before more sand is needed?
    Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Need a Sand Filter Expert
    If your filter is operating properly--you should never need to add sand.
    Jul 2015
    Aiken SC
    33
    Quote Originally Posted by woodyp View Post
    Even if you do a backwash?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Many people often mistake sand in their pool for dead algae. Capture some of it and let it dry and see if it is really sand. A sand filter shouldn't put any sand in your pool unless it is malfunctioning. You can also Perform the Overnight FC Loss Test (OCLT) to see if there is algae in the pool.
    Also adding your pool info to you signature might also help us to better help you, Pool School - Read This Before You Post
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,523
    Quote Originally Posted by timlab View Post
    Backwashing doesn't cause you to lose any sand. It just flushes out some of the gunk trapped in the sand. Be sure to rinse thoroughly after backwashing before going back to filtering.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    DFW, TX
    24,485
    This article from Pool School might be helpful, Pool School - Maintenance and Cleaning of Pool Filters
