Thread: Foam fitted inside pool frame -- did I do it wrong?
    May 2016
    Denver, CO
    7
    Quick question, as I'm starting to fill and suddenly slapped my forehead.
    I've got a 16-foot round hand-me-over Doughboy pool, and I found a great deal on the 2-inch thick XPS foam, so after leveling I made a floor with the foam and Tyvek tape, and installed peel-and-stick foam coving.
    I've got the pool frame and the foam on the same level surface -- in other words, I cut the foam panels to form a circle that fit inside the pool walls, rather than underneath.
    The fit is great, the work was long, it looks nice -- but did I mess up? Is there a structural need for the bottom, say, inch-and-a-half to be pressing against the bottom rails, rather than putting the pressure an inch or so higher on the wall?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Foam fitted inside pool frame -- did I do it wrong?
    Welcome to TFP Stick around and enjoy the party... Grab a great test kit and be ahead of the game
    That is the exact way I was going to do it before I got my intex pool... That is also the same exact way the sand is done so I do not think you have anything to worry about...
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,387
    That is the best way to do it. The cove will keep the liner from going between the foam bottom and the wall.
    Kim
    May 2016
    Denver, CO
    7
    Thanks folks! I don't know why that was giving me fits.
    Unfortunately I got about 16" deep before I spotted a leaky seam, so I get to wait on a new liner to come. Fortunately they're replacing it free, unfortunately it's gonna be hot the next few days!
    And thanks for the welcome, I'm already reading the instructions for my test kit. And pricing store bleach!
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    159
    If I have a unibead liner, where do I want the top of the foam to be level with? I plan on a similar build.
    Casey's Avatar
    SW PA
    10,421
    Quote Originally Posted by cowboycasey View Post
    Very interesting. I've never seen it done this way.
