Results 1 to 17 of 17
Thread: Any VS pumps with open communication protocols?
    Jun 2015
    Charlotte, NC.
    82
    Looking to integrate a VS pump (or full pump line) with my automation system. Are there any brands of VS Pumps that use a published or open communication protocol for selecting pump speed. I know there are some that can use separate relays for separate speeds, but i am looking for one that could be completely software controlled.
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Any VS pumps with open communication protocols?
    LOL, you are FUNNY!!!!
    More seriously though, none that I know of and it has been asked before. It would be great if they would release that. I know I saw a thread long ago as well where someone was monitoring the serial link to try and figure it out but nothing was really figured out.
    There is so much ability in most controllers today that can't be used simply because their menu interface doesn't have the options
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jun 2015
    Charlotte, NC.
    82
    I was afraid of that. I'm currently developing a automation system, but once I get that to market (if it sells) I'll look into coming up with an open-communication VS pump or maybe just a replacement motor for an existing pump housing.
    - Matrioux
    Mar 2015
    380
    If you get it figured out, and not too expensive I'd be onboard!!!
    Drives me crazy that my controller has ALL logic needed. AND, OR, NOR, etc. along with all needed sensors, yet because they didn't add it to their menu options I can't set my SWG to run when main pump is on, AND it has flow, but NOT between hours of x-y.
    No reason my SWG should run just because my grandson wants the fountain on. I get around it with creative wiring and relays, but I shouldn't need to.
    It's like going back to the late 80's for information technology. 1200 baud modem to a BBS, lol.
    Scott
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    What he said. In case it wasn't clear. NO!
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Are you using off the shelf software or scripts? Just curious. I'm pretty sure you will need some type of serial interface between the software and the pump. Richard Kinch in this article appears to have done some extensive research and work in automating pool controls using Linux and serial interfaces.
    5900 gal Oval 17' x 12' x 54" Sharkline Navigator 54 AGP; 1.5 HP Hayward Power-Flo LX Pump; Hayward EC65A DE Filter; AquaComfort XL ACT-750 Heat Pump;
    Hasa 8 gal Liquidator;
    TF-100 Test Kit w/Speedstir
    Jun 2015
    Charlotte, NC.
    82
    Custom writing software and building a controller board using a set internal protocol but will include an open interface for integration with other home automation systems.
    Because of my base system, I can integrate other communication protocols but need to determine my hardware needs so I can begin prototype production.
    I'll certainly check out the link, thanks!
    - Matrioux
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Very cool. If you are compiling your own software and building controller boards than this article will provide you with some hardware basis or ideas for your project.
    I am a systems engineer and find this stuff very interesting. Please PM me with some details when you have your prototype laid out.
    Good luck!
    ColdAirGuy's Avatar
    California
    85
    Hey, I was just speaking with a Vendor we use at work and he mentioned these "easy i/o" controllers he is using and building programs for. Believe he mentioned the "workbench" is internal to the controller as well. Check out the website. Easyio
    Internet based Bacnet, Sedona, Modbus.....I don't see why one couldn't purchase an inexpensive vfd online and use one of these to make their dreams come true. Obviously you need to have the skills, which I presently don't.
    Anthony 16,000 Gallon Oval, White plaster, 30' Long 15' Wide 5 1/2' Deep end 3 1/2' shallow end.
    Pentair Intelliflo, FNS Plus 60sf. DE, Pentair Intellibrite 5G
    TF100 Testkit
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Do we know what the hardware layer interface is? RS-232, RS-422, RS-485, CAN? Or something else?
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Quote Originally Posted by ColdAirGuy View Post
    Very powerful controllers. If you could sideload software onto it lots of possibilities.
    Dec 2014
    Riverside California
    482
    Hardware layer for at least Pentair is RS-485. You could get a serial communication analyzer Like this one to view the data between say an Easy Touch and Intelliflo pump.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2015
    Charlotte, NC.
    82
    I know Jandy uses RS-485 and I believe Hayward does as well. The problem is that the actual control commands are archaic, undocumented, and change by version of the equipment (all meant to keep people from doing what we are trying to do). I will look into communication analyzers but have little hope of coming up with something that works well enough to market. I do know that someone (I have forgotten the company name) has made a controller that speaks Jandy (and I think they have one for Hayward as well).
    Right now, my controller (at least the prototype) can handle just about everything from various manufactures except VS pumps. I can even use Jandy (and plan to add Hayward and possibly others before launch) salt cells with my salt controller so that if people are changing out there current systems, they don't need to re-plumb or wait for their current cell to die. That also means I don't have to manufacture my own cell.
    Eventually I want to have a full line of products, but being able to integrate equipment from other manufactures will help me position for replacement/upgrades as well as new builds and make the product viable until I can get a full line into production.
    I will look into the easyio items, but most pool control is relay based and not super complicated and only the few "smart" items like VS pumps and salt controllers need true communications
    - Matrioux
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I have used RS-485 for many years. I have no personal interest in developing a pump automation controller, but I DO like a challenge. Not saying that I have reverse engineered some protocols in my day, but, well, you know.
    I have a Pentair VS pump. I am assuming all the manufacturers' protocols are different and proprietary. Is there really any value in this endeavor?
    Jun 2015
    Charlotte, NC.
    82
    I don't think so. I think I will just stick with what I am developing. Once I have it on the market I may just develop an open control module for my own VS pump
    - Matrioux
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Now you are talking. If you want any help with an open protocol i will be happy to be on the committee.
    Jun 2015
    Charlotte, NC.
    82
    Might be a while, but I'll PM you if/when the project gets going, Thanks!
    - Matrioux
