Results 1 to 17 of 17
Thread: First numbers this season
    Aug 2015
    Greenwood Lake , ny
    27
    Last year I had a lot of problems with algea at the end of last year and thanks to this forum finally got it near clear when it was time to close it. Just had it opened it couple of days ago and happy to report that it is clear. Just needed to get the debris and git out of the bottom. I also installed a new sand filter (found out old one was undersized). These are the numbers from my TF100 kit today
    FC-9.5
    CC- 0.0
    Total Alkalinity 40
    CYA 50
    PH 7.2
    Any thoughts?
    Thanks everyone
    30,000 gal inground, vinyl, Hayward sand filter, 1 hp pump, Well water make up, Raypak heater w/bypass, TF100 testing kit.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: First numbers this season
    TA is a little low, everything else looks good to me!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Your TA might be just fine--see how fast your Ph rises. That will tell you.
    Aug 2015
    Greenwood Lake , ny
    27
    Thanks!
    Aug 2015
    Greenwood Lake , ny
    27
    Raised my TA to 110 but PH is high (Over 8) Using PH minus to bring down. Pool is very clear. Only problem is I have some brown dust on the bottom at the low end. Every time I vacuum it it's back two days later. It is so fine that if I go near it with the brush it disappears. I was trying to brush it together so I could vacuum to waste real quick. Could this be dead algae? Or is it just pollen?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    What are your recent test numbers? Have you been maintaining your minimum FC? Do you have a lot of pollen right now?
    Best way to tell if something is growing in your pool such as algae is to perform the OCLT. Pool School - Perform the Overnight FC Loss Test (OCLT) When doing so, I recommend having your FC at 5 ppm or higher when starting the OCLT.
    Isolated Spa - 345 Gallons
    Aug 2015
    Greenwood Lake , ny
    27
    Thanks Train. Will do OCLT tonight and report back tomorrow.
    Aug 2015
    Greenwood Lake , ny
    27
    Okay. I did the OCLT starting at 8:00 last night and FC was 3.5 (didn't have time to get it over 5 but pool school says over 3 is OK for test so I did it)
    Numbers as of 7:00 this morning
    FC=3.0
    CC=.5
    TA=110
    PH=8.2
    CYA=60
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    pH needs to go down. Muriatic acid is cheaper / stronger than "pH down", can find it at Lowes or Home Depot. Avoid the "green" version.
    How's the water look?
    Aug 2015
    Greenwood Lake , ny
    27
    Water is clear.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Good. Just noticed your FC is low for your CYA Pool School - Chlorine / CYA Chart For 60 CYA, always target 7, never below 5.
    Jun 2014
    15,298
    Brown dust, very fine but still passed your OCLT huh? Probably too cold to get your hands on any of that stuff. Have you tried adding a little DE to your filer to see if that helps? Pool School - Add DE to a Sand Filter
    If the DE has no effect, you might find yourself needing to bump-up to SLAM level for a couple days just to see if it effects that dust at all.
    Very good point!
    Aug 2015
    Greenwood Lake , ny
    27
    I've put 3 cups of HTH D.E. Filter aid in the swimmer so far and it hasn't moved the gauge needle. Should I continue till it does? Filter and gauge are brand new.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    *Skimmer?
    I would make sure it's not coming back into the pool somehow. That is a lot of DE, usually a solo cup full is enough for me. As long as you are confident your gauge is good (goes to 0 when pump off, rises slowly over time and is consistently the same post backwash) you should be ok to keep putting it in.
    Aug 2015
    Greenwood Lake , ny
    27
    Yeah Skimmer. I'm confident gauge is good. I'll go one more cup than watch.
    Thanks Mr. B
    Feb 2014
    Central Minnesota
    5,080
    Mine takes about 3 cups to raise 1 psi, 27 inch sand filter. I usually put it in a bucket with a couple gallons of pool water. Swirl, dump slowly, rinse, repeat until bucket is clean.
    Aug 2015
    Greenwood Lake , ny
    27
    Well live and learn. Before I put another cup in the skimmer I checked the gauge again. Still the same 15 PSI. Than I thought about what Mr. Bruce said about the gauge going to 0 with the pump off. So I turned it off. Went to 0. Turned it back on and boom its 17 PSI. Glad I didn't put anymore in. Vacuumed 3/4 of the pool and system spit the hose attachment off of the Skimmer. Gauge at 26 PSI. Back washed and finished vac. Back washed again. Gauge at 16 PSI. Bet it goes to 15 when it settles down. Pool is cleaner than it's been in years but have the feeling I'm going to have to do D.E. Again. And I think brown stuff is tree pollen.
    Thanks for the help. You people are a God send.
