Thread: labeling PVC pipes at pump station
    Mar 2009
    Charlotte, NC
    539
    I've used indelible markers but they fade.
    Any suggestions?
    Is there a permanent paint for PVC?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: labeling PVC pipes at pump station
    I have a brother label maker and used permanent labels. They have been on for 4 years now, look like the day I put them on.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    You _could_ buy pipe labels. They're used in industry/process/commercial piping installations, available in many wording, size and color options. You can probably find all the "Intake", "Return", "Filtered Water", directional arrows, etc. from Craftmark, and you can get them for about half a buck apiece, but you have to get 10 at a time. So you'd be in for 5 bucks for 10 of each label you want. Pricey, but you could have the sharpest looking filter plant in the neighborhood.
    Ohio
    87
    I was trying to find a good answer for this as I am replacing all of my plumbing with Schedule 40 PVC while adding solar panels and controller. I located what looks like to be a nice system on the web for a product called SnapMarker. They are square labeling plates that snap onto your piping and then you apply the correct label to the plate for identification. They have a specific set of pool labels shown on the website.
    The problem is it appears they only sell through distributors and I could find no pricing on the website . I have not tried to contact them to see if there is a distributor in our area or how they could be purchased if they are not cost prohibitive. I think it makes a clean and neat way to label the piping IMHO.
    You can see more information on their website. http://www.snapmarkers.com/home.shtml. To see the pool specific labels just click on the swimming pool link under specific applications in the upper left corner of their webpage.
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    I strongly recommend the Brother brand label makers. Look for a model that takes the laminated indoor outdoor label tape. They can be gotten for around $30 and are useful for just about everything. The Brother PT-1280 P-touch Electronic Labeling System is a good choice right at the moment, though some people might want to go for one of the fancier models.
