Results 1 to 10 of 10
Thread: Pump Timer Issues.
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Pump Timer Issues.
    Hello All,
    Can you check this photo and let me know what time my pump would turn on. Normally i adjust the left dial, the right one i guess is for the second smaller pump that i have (which i have no clue what its for)!
    I want it to run from 11:00 to 15:00. But i woke up at 7:30 today and saw the pump running at that time. Who knows how long it was running for.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    Mar 2016
    Chicago,IL
    88
    Re: Pump Timer Issues.
    You need make sure the middle silver dial is at what time it is. It says it is 7:30pm when you took this pic. Is that correct? If not you need to pull lightly on the whole yellow circle and turn it till it matched the time it is with the silver arm.
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Jul 2015
    Richardson, Texas
    182
    Ok... so i need to set the center arm to the current time on the clock? The photo was taken sometime around 10:30 CST.
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    The right clock controlling the small pump sounds like it is a pressure side cleaner.
    Jul 2015
    Richardson, Texas
    182
    Ah! Is that supposed to run, the last time when some pool guys came to install my main motor, said its not supposed to run.
    P.S. I think i got the timer to work properly now. Thanks. Will see tomorrow if it turns on at the right time.
    TFT-100 Test Kit.
    DX5+S Cleaner.
    DFW, TX
    24,497
    There should be a fitting in the pool that sort of looks like a return only bigger and higher up, closer to the waterline tile. Plug a pressure side cleaner in there and turn on that booster pump and watch it go. Most booster pumps also need to have the main pump running too.
    Jul 2015
    Richardson, Texas
    182
    Hmm... I have to look for that. I will try to find it out tomorrow morning. Thanks.
    TFT-100 Test Kit.
    DX5+S Cleaner.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Quote Originally Posted by hellstorm2004 View Post
    Not quite. The center aluminum colored arm does not move. Leave it alone and just consider it a pointer as to the time of day. Pull out the yellow dial and rotate the yellow dial so that the current time of day is under the aluminum colored pointer.
    The timer works exactly opposite of a normal clock. The pointer is fixed and the dial rotates. Set the dial. Do not try to move the pointer.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Jul 2015
    Richardson, Texas
    182
    Yeah. That is what i did. Moved the dial, not the arm! Tried to move the center arm long time ago, when i was a pool newbie. Realized it was not the right thing to do!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Great. I've been there!
