Thread: Can over-shocking cause damage? Water level down 3 inches
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    I had a really bad case of Algae when I opened up my pool last week (I am in NJ). I went a little over board and over loaded with bleach (added something like 18 gallons). I have been running my pump non stop for the past 4 days. Today I noticed the water level is 3-4 inches lower from 4 days ago. We have had cloudy weather and temps in the 50's, so I know it didn't evaporate from the hot sun. I never had this issue before and had the pool for about 9 years now. Could my over shocking it cause a leak somewhere?
    20,000 gal, In-Ground (built in 2007)
    Vinyl lining / 1HP Hayward SuperPump / Hayward Pro-Grid DE Filter / Hayward Gas Heater / Liquid Chlorine,Bleach (4 Gallon Liquidator)
    Dohney Discovery Robot
    Testing Method: TFTestkits/TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Can over-shocking cause damage? Water level down 3 inches
    What were your test results before the the addition of 18 gallons of bleach, and after? What's your CYA level in particular?
    I've heard of overly high, non or under stabilized water bleaching liners but I've never heard of them causing leaks. Unless maybe if your liner was already old and damaged....? Is your liner 8 years old? It might have been on its last legs and whatever was done at opening caused a tear/leak. Did you rake out leaves or vacuum?
    addendum: Why are you using CalHypo? Vinyl pools don't actually need a any/much calcium.
    Jun 2014
    15,205
    I would find that very unlikely. A coincidence perhaps. I'm assuming you had your pool winterized, so you had to reconnect everything and blow-out any line protection you had in there from winter. At this point, all you can do is try to isolate the source and go from there. Start with plugging all the returns, skimmer, drain, etc to see if it's just the liner or something that protrudes through the liner (i.e. around a fitting or light). If that doesn't work, try to isolate sections of your system (suction, pressure) to see if you can narrow it down. Perhaps the Pool School - Leak Detection will offer some insight as well.
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    Quote Originally Posted by Texas Splash View Post
    Thanks,I look into it further.
    Quote Originally Posted by YippeeSkippy View Post
    Since I just opened the pool, I started with getting the PH and TA to the proper levels then shocked. Didn't bother checking CYA yet. I closed the pool last year with some alge issues that I thought were taken care of. When I opened the pool last week, it was green like a swamp.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Maybe he has a heater.
    Dolphin E10 Cleaning Robot.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Such nuking approaches to Chlorination is just asking for problems particularly with a vinyl liner pool, this is part of the reason we teach testing and appropriate level of dosing, not just the dump and pray or nuke it approach.
