Results 1 to 7 of 7
Thread: Ionizer
    May 2016
    Paramus / New Jersey
    26
    Ionizer
    Hello,
    Is an Ionizer worth the investment? In-line VS floating matter much?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Ionizer
    No. Not needed and can cause staining issues. Waste of money.
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Re: Ionizer
    Ditto what he said.
    What do you mean "In-line floating matter much" ??
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Ionizer
    The best way I can sum it up is that an ionizer is like paying to have more problems with your pool.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2016
    26
    Re: Ionizer
    HAHAHA! Thanks for the feedback!
    Quote Originally Posted by YippeeSkippy View Post
    Ditto what he said.
    Based on my research, there are models that can be plumbed into an existing system, and models that float in the pool. Understand?
    Jan 2012
    7,273
    Re: Ionizer
    Quote Originally Posted by yesjenks View Post
    Yup, got it. Thanks for the explanation.
    Don't waste your money on either!
    Yippee
    rajung's Avatar
    Mar 2015
    Iowa
    185
    Re: Ionizer
    Hello,
    Disconnected mine last year after the same question I posted on the board.
    Plugged the port where the flex tube connected with a vacuum plug.
    Frees up another electrical outlet.
    Never looked back and pool water results are same as before using the TFP method.I was upsold during pool purchase from local installer/store.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
