Thread: OmniLogic History
    Apr 2015
    Tulsa, OK
    11
    OmniLogic History
    While using the Hayward OnmiLogic website, there is a history view at the bottom of the menu on the left. When I click this view I see just a few entries showing air temp and water temp. No matter what dates I enter in the date range fields I can only see these half-dozen or so entries in the history. Is there a way to see a larger date range of history?
    Attached is a screenshot of this morning's history. As you can see the date range is set from the 1st through 5th. I then clicked the Search button and I see the same 4 entries I did when the view first loaded.
    44k gal, IG gunite/plaster, spillover spa, waterfall features, OmniLogic automation, TriStar VS pump (filter), 1.5HP TriStar pump (waterfalls), Hayward S310T2 sand filter, TurboCell-15 SWG, Hayward H400FDN gas heater, Dolphin Z5 cleaner, TF-100 test kit.
    38,301
    Re: OmniLogic History
    No idea. There are very few users of that automation system since it is fairly new. You might have better luck contacting Hayward ... please report back what you learn
