Results 1 to 11 of 11
Thread: Recommended Variable Speed motor?
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Question Recommended Variable Speed motor?
    So now that I understand the TFP method, and pool is clear, and all is well, so I started looking at my equipment. The previous owner ran the filter 24/7, and over the last month I did same, as I was not sure of the runtime, and also we have had some bad storms. But yesterday, I got our power bill! Ouch. Costing about $5/day to run this dang thing! So I cut the runtime down to 8 hours a day for now, and will lower more once I get comfortable.
    Question is. I have a Pentair Challenger B2854, which upon lookup on the Google Machine tells me it is 1.5 HP. It's only about a year old, and works great, but it's a single speed. I have a good amount of trees around me, so when filter is not running at all, stuff gets in pool. And we have this pollen stuff that when it sinks to the bottom, it stains the plaster!
    Any recommendations on a variable speed motor? Appx. cost? Would it be beneficial for me to get one?
    thanks for any help you can provide. I love this site!
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    B2854 Pentair Challenger 1.5 HP single speed motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Re: Recommended Variable Speed motor?
    Also, my local power company, CPS Energy in San Antonio, offers a $200 per horsepower rebate if the new motor is Energy Star Compliant.
    -Paul
    mas985's Avatar
    Pleasanton, CA
    11,737
    Does your energy company require you to purchase an entire pump or just the motor? Century makes a VS motor that will fit your pump head. A.O. Smith 1.65 HP Variable Speed Pool Pump Motor Square Flange - ECM16SQU - INYOPools.com
    Also, a two speed motor is another choice although you probably won't get a rebate for that. A B2982 is the equivalent two speed for that pump head. But given the rebate, it might not cost much more for one of the cheaper VS pumps.
    Mark
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Thanks, will take a look at that. Is replacing a motor a tough task? I am pretty good with other stuff, just never worked with pool stuff. Would it be easy to switch out this motor? For $400 this seems like a good deal.
    Here is the info on the rebate. Does say ""Motor-only replacement does not qualify. Nor does rebuilding an existing pool pump" So to replace the whole pump vs. the motor, what does that entail? What additional parts is that?
    https://www.cpsenergy.com/en/my-home...mp-rebate.html
    -Paul
    mas985's Avatar
    Pleasanton, CA
    11,737
    To replace a motor, you only need a Go_kit which has the motor seal and gaskets. But again, given the rebate, it may not make sense to do that. You would have to price it out. Because of the energy savings of a VS over a two speed, the two speed usually has to be more than $300 cheaper for the two speed to make sense.
    Any of the lower priced VS pumps would qualify but if you have a Pentair controller or prefer Pentair, take a look at the Pentair SuperFlo VS.
    Mark
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    I gotcha. I am not sure I prefer Pentair, that is just what I have.
    I see this on Amazon. So with this you are just changing out the hoses/pipes right?
    http://www.amazon.com/Pentair-342000.../dp/B00J8W36L6
    thanks for your replies!
    -Paul
    mas985's Avatar
    Pleasanton, CA
    11,737
    Right but I don't think you should have any hoses. It should all be schedule 40 ridged PVC.
    Mark
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Replacing a motor isn't hard. But the problem is getting some of the parts off. Due to water and corrosion, some of the bolts are stuck so tight, you need to be Hercules to take them off. I ran into the same problem. Had to call the professional, even they were not able to do it. They asked to get a new part!
    And A.O. Smith is a very good brand. They do make some reliable pumps.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    I put a small dab of grease on the main motor bolt threads whenever the motor is removed (seal replaced etc...)
    Dolphin E10 Cleaning Robot.
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Quote Originally Posted by mas985 View Post
    For the Pool pump yes, you are right, only PVC. There are some hoses on the motor that powers the Polaris. Not sure if that is right or not, but that is what I have...
    -Paul
    May 2008
    Long Island, NY
    151
    I have a Ecotech VS motor. I have had no issues with it.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
