Results 1 to 13 of 13
Thread: What is this sign my pump is making?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Hi All,
    I've noticed that when the temps are cooler (at least I believe it's only when cooler), maybe sub 55 degrees, my pump emits this odd scratchy sound. The hum/running sound of the motor seems fine and consistent, but this is an additive noise sometimes. No idea what it is, or if it could be the sign of a soon to die bearing or something. System is only 3 years old. Again, no extra noise when the temps are higher. Anything to worry about?
    Here's a clip of the sound. Listen for he inconsistent sound - the scratchy, leaf ruffling sound, or like a can with sand in it is being shaken vigorously...
    Pump Sound Clip
    Thanks for the help!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: What is this sign my pump is making?
    I dunno.......................but my bones creak more lower than 55 too!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Ha ha. You could hear it though? Hmmm.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,769
    Can you isolate the noise to either the pump head or the motor? Try taking a large screw driver and placing the handle to your ear and the tip to different parts of the pump and motor. That can often help isolate pump noises from motor noise. If it is temp related you might have a slight air leak in the strainer basket o-ring, or another suction fitting due to thermal shrinkage. best thing you can do is try and isolate the cause and keep an ear out for changes in the noise.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I'm pretty sure it's the motor, not the pump head. I can double check tonight though.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,769
    My first guess at that noise would have been pump side suction noise.
    If it ends up being the motor, in my experience that tends to be a bearing sound. I've heard pumps run like that for a long time with no change and some go down hill quickly after making that sound. Don't panic just keep an ear out for any changes in noise. Maybe look into a nice VS motor up grade for that pump head. Last I looked a complete tristar VS pump was running about $750 with free shipping.
    Chuck-
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Hmmm. Maybe it is pump side then. I'd be shocked if it was the motor already. It's still under warranty though, through October. I'll take a closer look (listen) tonight.
    Stupid typo in the thread title too. What "sign" vs "sound". I need to slow down.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Just fired up the motor (it's about 50 degrees right now) and heard it. Definitely motor end, not wet end...
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,769
    If it's motor end and it's still under warranty I would start talking with the people you got it from about replacing the motor. They do go bad but that's why they warranty them.
    Chuck-
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,455
    LOL on the tile! My eyes read it as sound! No worries but I can change it if you want. PM me if you really want it changed.
    Kim
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I think we all have it figured out at this point that it's sound...
    mas985's Avatar
    Pleasanton, CA
    11,737
    It sounds a little like cavitation to me. Can you get closer to the pump outlet and record the sound. It is a little muffled.
    Did the pump always make this sound or did something in your plumbing change recently? New pool cleaner, valve settings, anything....
    Mark
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    It only makes the send when the outside temps are cooler, not always. I'm revised my temp in the first post too. I'd say sub 45 degrees, is when I hear it. It was 48 last night, and no noise. Very strange. And no, nothing has changed.
