Results 1 to 7 of 7
Thread: Liquidator and air bubbles
    Dec 2015
    Newington, Connecticut
    113
    So I recently changed the 3/8 fittings with the original barb fittings to see if my air bubble situation would resolve. the bubbles are definitely coming from the tank. When I tap on the tank I can see the bubbles pass through the tubing. the air gets trapped in the flow guage, otherwise probably wouldn't be a big deal. I tried wiping all bubbles from the interior of the tank but they form back on the sides. is this a typical occurrence that others experience with the liquidator? A reaction with the 12.5 and pool water? Can't figure this one out.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Liquidator and air bubbles
    I feel the pain been there. I never had bubbles coming from my tank. From the fittings yes. I would take apart and reassemble the fittings. It worked for me.
    Dec 2015
    113
    Are your tank walls covered with bubbles. I get that new plastic will due that when its first filled with water but the keep relining the tank. I have the system valve opening full and the bubbles aren't getting stuck in the flow meter. Worst case scenario I can make a plastic baffle and install below the output valve
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I get air bubbles that form on the inner walls, but honestly, they do not seem to be a problem. As in they do not get sucked into the output. Maybe its your output fitting that is leaking air? If I tap the tank, the bubbles just seem to rise to the top.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Dec 2015
    113
    Liquidator bubble issue update
    I cut a seven ounce plastic drinking cup to fit below the output float assembly to direct the bubbles rising up from the bleach around the valve. Bubbles have stopped entering the tubing and now I can see where a threaded connection to the flow gauge is slightly leaking. Will use teflon paste instead of Teflon tape to stop air leaks. Also made a shade box with used pallets. Rustic look which blends into the shrubs and mulch bed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Liquidator bubble issue update
    Nice work!
    Ellington, CT
    262
    Quote Originally Posted by Andrew Howard View Post
    ...and now I can see where a threaded connection to the flow gauge is slightly leaking.
    This is a common problem and i believe i read somewhere in this forum that the threads on the flow indicated and the mating threads are mismatched. Anyway mine leaked also and i just don't use it anymore.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
