Thread: How are these numbers? Any suggestions?
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    116
    I am just coming off a SLAM. Pool is crystal clear. Should I be concerned with the High Alkalinity? I was going to add a little chlorine to keep it a bit higher with the CC of 0.5. Any other suggestions?
    FC 9
    CC 0.5
    pH 7.6
    TA 120
    CH 400
    CYA 70
    Temp 74
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    B2854 Pentair Challenger 1.5 HP single speed motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How are these numbers? Any suggestions?
    Short answer: no.
    When the pH rises to 7.8, add acid to get it down to 7.2. That'll shave 10 points off the TA right there. It'll come down over time as long as you maintain pH. There's no point in getting aggressive with it.
