Thread: Adding Borates into pool is it worth it? Will it say what it does prevent algae?
    Apr 2015
    Nashville
    40
    I am still having a slightly greenish but turning blue SWG pool with all near to optimal now. Do I add the borates (20 Mule 4lbs Box from Walmart) or do I do this after the pool is balanced?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Adding Borates into pool is it worth it? Will it say what it does prevent algae?
    I would wait until it is all cleared up and get your TA set and your PH stable first. Then borates in. I like mine.
    Please add your State to your location in your profile so it shows up over there <-----, climate is an important factor when we are helping you with your pool. And you can add your pool info your signature so that we know what we are helping you with, more here Pool School - Read This Before You Post
    38,251
    Borates are completely optional and I would wait until your pool is sparkling clear and balanced before even considering them. They really are a very very minor impact on preventing algae.
    Apr 2015
    Nashville
    40
    Thanks a lot.
    Apr 2015
    Nashville
    40
    Does adding borates really help to prevent algae seriously.. What other advantages is there?
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by phillipjko View Post
    Sent from my iPad using Tapatalk
    Borates - Why and How
