Thread: OHH error bypass
    May 2015
    Waterloo, Ontario
    51
    OHH error bypass
    I have a 2007 hydropool 650. The tub was getting an ohh error and the sensor was reading much higher than actual temperature. I could still use the topside panel and the error would go away after a while once the water cooled slightly. I have determined that it is likely faulty heat sensors so I have some on order . The OHH sensor is now permanent and I can't reset or do anything. Tried resetting the breaker resetting memory ect ect but the error keeps coming up and I can't do anything with the top side panel.
    I want the pumps to run so water continues to circulate but I can't do anything. Is there anyway to bypass or allow the pumps to run without the heater or sensors operational ? Sensors won't arrive for a few days and I want to make sure I at least have filter cycles on.
    1999, 18x36 29k Gal, IG Vinyl, Sta-Rite Intellipro VS, Pentair SD80 Sand Filter, Pentair Millivolt 250m NG Heater
    2007, Hydropool H625 Platinum, 3HP/4HP pumps, Balboa Spa pack, Poly Planar Stereo c/w pop up speakers
    Casey's Avatar
    SW PA
    10,457
    Re: OHH error bypass
    Bumping for help.
    May 2011
    The Netherlands, Europe
    49
    Sorry, don't have a clue how you can bypass this problem. Have you tried shutting the tub off for an hour? Then put the power back on, perhaps that helps?
    Sunspa Monaco in the garden since March 2011.
    May 2015
    Waterloo, Ontario
    51
    Ok, I replaced the sensors but still no luck. I tested the resistance on the heater and its 15.2ohms is that within spec for the heater element ?
    I also removed board and inspected the back of the board for burns in case something was fried but nothing. Could it be a bad relay or pump related ? If it was pump related I would think I could still use the functions on the topside panel but not sure. OHH error is constant and I cannot do anything else even after shutting down for extended time period. Any ideas could it be the heater element or does the resistance check out.
