Thread: Help with vacuum
    jrowe0311's Avatar
    Mar 2016
    Thomasville
    18
    Help with vacuum
    Hey everyone I finally got my pool right with the test kit everyone suggested I found out cya was to high emptied out water got that right and just started with bleach. It's amazing the difference it made. Right now I am struggling with just a few leftovers in the bottom of the pool. Anytime I vacuum it stops up because of these teeny tiny little sticks in it and when I say tiny I mean tiny. Also I still have gumballs in it that I am trying to get out but hard to see in the clump of mess that's in the bottom of the pool. It's not like there is a ton of leaves and dead algae just sitting there but it's everything sitting together. Any ideas to limit the stopping up of the vacuum? I can barely vacuum anything before it stops up.
    54 inch by 27 foot round above ground pool.
    Jun 2014
    15,109
    Re: Help with vacuum
    Even the best of vacuums have their limit. Do you have anything that you can sweep or pull gently across the bottom to try and manually scoop the majority of it our with first?
