Thread: Pool Heater Exchange - Still Good to Use?
    May 2016
    Oswego / IL
    2
    Hi All Ė
    Last year I didnít do a very good job keeping my PH up and there was some corrosion in my heater exchange where the copper levels were high in my pool. I bypassed the heater with the plumbing, drained and refilled and took care of the copper issue.
    As we head into the new swim season, my question is, the heater exchange wasnít leaking or anything like that last year, so can I hook the plumbing back to the heater or will I run into the same problem with the copper because of whatever corrosion happened?
    Or would you suggest just changing out the heater exchange to be on the safe side?
    How do I tell if the heater exchange is still good to use?
    Thanks a lot for any feedback.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: Pool Heater Exchange - Still Good to Use?
    Welcome to TFP!
    If it isn't leaking it is probably fine. Just keep an eye on it. Keep your PH at 7.2 or higher at all times to avoid that in the future.
    May 2016
    Oswego / IL
    2
    Thank you.
