Results 1 to 9 of 9
Thread: Help please
    May 2016
    Hopkins South Carolina
    14
    Help please
    I have a 16inch saltwater intex filtration system with a 10inch sand filter. Am I going to have any issues seeing that one is 16inch and the other is 10inch..... Please help
    38,295
    Re: Help please
    Welcome to TFP!!!
    I do not follow ... are you trying to use 2 filters?
    May 2016
    14
    Re: Help please
    No sir. I have a 16 inch saltwater filtration system with built in pumpb and I wanna see if I attach that to a 10inch sand filter no pump will I have issues seeing how one is 16inches and the other is 10inches
    May 2016
    14
    Re: Help please
    No sir. I have a 16inch intex saltwater system with built in pump. And a 10inch sand filter no pump. I was wanting to know if there would be issues since the saltwater system was 6 inches bigger than the sand filter
    Not sure if that would be 2 filters since the sand filter is the only filter the salt water is just for chlorine
    38,295
    Re: Help please
    Yeah, that does not make any sense.
    When you say "16 inch saltwater filtration system" and know it is Intex, I would expect that to include a pump, a 16" sand filter, and a SWG (saltwater chlorine generator).
    The 16" has nothing to do with the SWG.
    I think you are going to need to post some pictures.
    May 2016
    14
    Re: Help please
    You are right on everything except the sand filter is only 10inches. The intex swg is 16inches with pump. Just needed to know if the 10inch sand filter had to be 16inches or could i use the 10inch sand filter
    So basically the swg is 16inches with its own pump. I damaged the 16inch sand filter that came with it and had a friend that had a 10inch sand filter. The sand fitler does not have a pump so can i attach the 16inch swg with pump to the 10inch sand filter and everything still function properly
    May 2016
    14
    Re: Help please
    And Im sorry I don't know how to post pics. The unit was a combo. But the sand filter cracked and had to replace it with a smaller size sand filter
    38,295
    Re: Help please
    Quote Originally Posted by michael803 View Post
    Well, now we are getting somewhere.
    The SWG is NOT!!! 16" ... the old cracked filter must have been 16". The SWG does not care what size filter is used. However, the pump might be a little too strong to go down to the smaller 10" sand filter resulting in dirt getting pushed through the sand and maybe getting sand into the pool. Plus you will have to clean the smaller filter more often.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Help please
    To post a pic upload it to Photobucket (free account), copy the IMG code to the right of the pic and paste it in your post. This will embed the pic in your thread.
    Did you measure the salt cell and it measures 16"? That is not how salt cells are sized, they are spec'd by gallons of pool size they are recommended for use with. Like 10k gal, 20k gal, etc.
