Results 1 to 7 of 7
Thread: SWG on with no flow
    SWG on with no flow
    Is it bad to have a salt water generator generating but with no water flow??
    Thx
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    Re: SWG on with no flow
    Yes, it's bad. Chlorine gas and hydrogen gas can accumulate and potentially explode.
    Support the site
    Yikes. Is it bad for the life of the salt cell??
    Salt Water
    Sand Filter
    Aug 2010
    Dallas, TX
    4,052
    I would think an explosion would be bad for a salt cell, yes.
    All the systems I have worked with have a flow detector to turn off the SWG when there's insufficient water flow.
    Jun 2015
    Ottawa/Ontario
    336
    I believe they called it Mustard Gas in WWI
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Quote Originally Posted by tlevy View Post
    No. it is not mustard gas. Mustard gas does have chlorine and hydrogen, but there are other elements as well. The formula for at least one form of mustard gas is C4H8Cl2S
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Jun 2015
    Ottawa/Ontario
    336
    Good to know. Thx for the clarification...still nasty no matter which way you slice it!
