Results 1 to 14 of 14
Thread: My Results vs. Pool Stpre
    Apr 2016
    Lafayette, LA
    16
    I've been doing the TFP method for about 2 months now, and as a result, have largely stopped going to my pool supply store. Recently they sent a bunch of coupons for free stuff and I needed a new sight window for my filter, so I figured I'd see how their numbers compared with mine. I was just curious if anyone had comments about the differences. The measurements were done 3 days apart, but I feel like that should be close enough.
    TC/FC
    - My FC number is 2.0, and I have yet to ever show a result for CC, so TC was 2.0. Is it weird to never show CC? I wonder if I'm doing the test wrong somehow.
    - The pool store showed 1.8 FC and 0.5 CC for a 2.3 TC
    pH
    - lately my color doesn't seem to match any of the colors in the vial, but previous to that it seemed steady at 7.5. My best guess was it had increased to 7.8 or maybe more.
    - They showed 7.7 in the computer, but the red dye test led the girl to think it was closer to 8.0 and so I just added a pint of acid. We'll see what happens, I guess.
    CYA
    - My very first reading was 65, but in the 2 or so months it has since come down to 45. I know there's a lot of ballparking in this one.
    - They showed 57
    TA
    - My test says 90, down from 100 originally, which is just on the high end of acceptable according to the recommended levels page.
    - Theirs has 2 numbers, TA of 99, and Adjusted TA of 82. They say this adjusted TA number should be 125-150, and wanted me to buy 16 pounds of Balance Pak 100 to raise it up. I didn't.
    CH
    - I show 225, which is on the low side, but it fluctuates a little above that sometimes, so my plan was to leave it alone for now.
    - Their machine said 201, which makes me think I ought to rethink that plan a little.
    Thanks for any comments, tips, advice, etc. (The pool is crystal clear, by the way).
    25,000 Gallon IG Plaster
    Sand Filter
    Pentair Challenger Pump
    Unknown install date
    TF-100 test kit
    38,284
    Re: My Results vs. Pool Stpre
    Since we do not trust pool store testing, I am not even sure there is a point to look at them and speculate on the differences.
    Having 0 CC is a good thing.
    Pool stores are the worst at the CYA test.
    TA of 90 is fine ... mine is 50 due to having a SWG and high CH.
    Using your numbers in PoolMath shows a fairly balanced CSI. If you lowered the pH to 7.6, your water would be basically neutral.
    Since you CH is a little low, just keep your pH in the upper 7s
    Jul 2015
    Central Valley CA
    1,107
    Total normal to not have CC especially if you don't have a high bather load and are not covering the pool for several days at a stretch. I do cover my pool and even with that only had the CC go to .5 a couple of times in the last couple of months.
    I find the PH easier to read the lower on the scale I go so I generally try to keep it in the 7.4 to 7.6 range when I start to get near 7.8 I have a hard time disguising the color difference.
    Might want to check the CYA one more time and once you have a reading you can trust adjust your FC up based on this chart
    I would leave the TA alone and adjust the CH up 75 to 100ppm
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Which Lafayette are you in? If you're in California, I'd seriously question the low CH and disappearing CYA. If it's the one in Louisiana that gets lots of rain, then it's understandable.
    If you're having trouble with the pH test, try doing it with 4 drops instead of 5. And if that doesn't help, add 2 more and see what it looks like.
    And finally...
    Apr 2016
    Lafayette, LA
    16
    It's the one in Louisiana. I had assumed the dropping CYA is from no longer using Chlorine hockey pucks. In fact, I took the whole chlorinator off the filter the other day when I noticed a broken line.
    Sand Filter
    TF-100 test kit
    Mar 2015
    South Texas
    411
    I was gonna say, the biggest thing I noticed is that you need to add some chlorine! With your CYA, your FC should be 4-6, not 2. You could get algae if not careful
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Apr 2016
    Lafayette, LA
    16
    Quote Originally Posted by nlindelldc View Post
    That's the other thing - it seems like if I don't do a whole jug of bleach every other day, my FC level is hard to keep up. Is that normal?
    Sand Filter
    TF-100 test kit
    Mar 2015
    South Texas
    411
    Quote Originally Posted by Chappie View Post
    That actually sounds about right. My pool is only 15,000 gallons and I add half a jug about every 2-3 days depending on sunshine and bather load. The good news is in the winter it drops off significantly
    Isaac-1's Avatar
    SW Louisiana
    6,711
    On a side point please add your state to your location, where you are effects some of the advice we give as it tells us your general climate, typical length of pool season, and in some cases even the likely hardness range of your water. All of these things are different between say Lafayette, IN and Lafayette LA, then of course there is LaFayette, NY, and who knows what else.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Just to be sure you have no issues I'd run a Overnight FC Loss Test (OCLT) just to be sure.
    Support the site
    Apr 2016
    Lafayette, LA
    16
    Well, there you go. I took it up to 10 FC which I checked at about 10;30 PM, and it was 7.5 at 7AM. There's also a bunch of what looks like dirt (and I assume is dead algae) in the bottom. When I inherited this pool last year it was in bad shape. I got it cleared up, but it looks like I didn't kill everything. I guess I get to try my first SLAM now. Thanks for the input, it has obviously been very helpful.
    Sand Filter
    TF-100 test kit
    Jun 2014
    15,103
    Apr 2016
    Lafayette, LA
    16
    Lol. I guess I was lulled to sleep by the crystal clearness of the water. I have some spots that I have brushed and brushed with the wire algae brush, but just cannot seem to remove. Maybe I convinced myself it was just a stain or something. Will I ever be algae free with these spots there, or will the SLAM eventually get them to come off?
    Sand Filter
    TF-100 test kit
    Mar 2015
    South Texas
    411
    SLAM and brush those hard to reach areas like crazy. If you brush it off the chlorine will no doubt kill it. Persistence is key. And I would SLAM an extra couple of days after you pass your OCLT just to be safe
