Thread: Low CH/TA
    Jun 2014
    Rogers, AR
    424
    Low CH/TA
    My CH and TA typically run on the low side and my ph rarely swings.
    All last year it ran solid at CH 100 TA 50 ph ran around 7.4 all summer. I used less than a half gallon of acid.
    My CH has dropped and I want to double check to make sure I am still running okay.
    Today's test results:
    CL 8
    CC 0
    CH 75
    TA 50
    CYA 40
    Chris
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Jun 2014
    15,067
    Re: Low CH/TA
    Your numbers are fine Chris, although you didn't list the pH. Chlorine (FC) is a little strong for your CYA, but okay for now. CH is just fine. As long as your pH is between 7.6-7.8 you are in good shape.
    38,271
    Re: Low CH/TA
    Your TA is fine if your pH is stable.
    Being that you have a vinyl liner, you do not need CH in your water. Although if it gets too low and you start seeing any foaming, then bumping the CH up a bit would likely help stop the foaming.
    You FC is a little on the high side for your CYA, but it is not really a problem.
    Jun 2014
    Rogers, AR
    424
    Re: Low CH/TA
    Thanks for the reassurance. I know my CL is a little high. I was talking and doing my CL test at the same time last night. I guess I can't count drops and talk at the same time LOL.
