Results 1 to 12 of 12
Thread: New Pool Build in San Diego -- Questions
    Feb 2016
    Carlsbad, CA
    28
    Hi All,
    First, this forum is awesome! This is my goto place for all advice around pools (definitely a little daunting with all the things to consider).
    So, we have been making progress on our pool build and the basics are as follows:
    • Pool 245sq ft with 71' perimeter (approx 8500 gallons) 3.5 to 5ft depth.
    • Spa 50sq ft with 25' perimeter
    • Intelliflo VS 011018 3HP (filtration)
    • Whisperflo 2HP (jets)
    • CCP 320 Cartridge Filter
    • Intellitouch Enclosure Kit Load Center with Intellichlor Trans
    • i7 Intellitouch Personality kit
    • Intellichlor Cell
    • ScreenLogic 2 w/phone kit
    • Pentair 400k BTU natural gas heater
    • Intellibrite 5g color pool/spa light
    • Thinking about solar...
    • 3 Pool Returns
    • 1 Skimmer
    • Sheer descent on spa and on raised back wall (24" center of raised back wall 30")
    • Gas and electric run to the back of the raised wall for firebowls to be placed on the left and right of the back. (Future)
    Ok, so we had shotcrete done but there are a couple of things that I wonder about:
    1. I noticed we don't have a dedicated vacuum port. Apparently I'm supposed to use the skimmer with a vac plate (e.g. the Pentair Rainbow)
    2. The spa seat width is only about 15" to 16" of shotcrete. When I sit on it I feel like it might be too narrow. What's normal? I've heard 18" and my neighbors is 17.5". I know that plaster/pebble will add about 0.5" but can it be "over plastered" to make it a little bit wider?
    Thanks!
    Feb 2016
    Carlsbad, CA
    28
    Re: New Pool Build in San Diego -- Questions
    I should have mentioned in reference to (1) about not having a dedicated vacuum port that my question is whether or not I should pay to have one put in (coring the shotcrete and running a new suction line). I've heard that it shouldn't be a "huge" deal to do and for sure it would have been better to get this done before shotcrete but I didn't even know about it until the solar installer came out and asked and the neighbors pool guy poked his head over the wall and asked and both said it was WAY better. Ugh.
    How much would you expect to pay for this? I've heard that it's done on renovations quite commonly. Trenches aren't filled and no decking poured so...
    May 2014
    katy. tx
    80
    or use a robot for cleaning the pool, aquabot or dolphin...
    Aug 2014
    NJ
    435
    I think his question is whether it makes sense to have a separate vacuum port as opposed to using the hole below the skimmer to vacuum.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    May 2014
    katy. tx
    80
    our pool builder in our last home left us with the skimmer plate and a length of hose attached to a vacuum head, end of story! after a few weeks of that, we purchased an aquabot.
    in most threads i have read on here, a robot cleaner is recommended over the suction type ike the polaris (with dedicated port) most of the time. I could be wrong... Pool Cleaners
    Feb 2016
    Carlsbad, CA
    28
    Yes, it does seem like robot cleaners are fairly popular on the forum and a lot of people love how well they work. My primary objection to them is not as much the cost but
    a) Pulling it in and out of the pool all the time instead of a pressure-side/suction-side which you can pretty much leave in.
    b) Running a power cord to it unless I run a new outlet somewhere a little closer to the pool so it wouldn't be in a walkway.
    My PB came back with a quote of $200 to core and put in a separate suction line so I'm going to go that route (vacuum plate alone would have cost me around $90'ish).
    Now my second question was the spa seat width. I've heard that 18" to 20" is standard (neighbors is 17.5) and my PB says 14" to 16" is standard.
    I asked him about shooting more plaster and he said max they can do is 3/4" to add extra width (like to go more up to 17 to 18"). Guess that doesn't leave me with many options... or does it?
    Aug 2014
    NJ
    435
    I agree with you reasons a and b above. Always seemed to me that robots were more of a pain than the Polaris even if they were better cleaners. Can't help you on the standard spa seat width
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Just an observation, I have a pressure side cleaner and wish I had a robot. I never leave it in because the hose kills the pool aesthetics (call me a pool snob but I love the look we've created down there) and it gets in the way of swimming and good pool fun.
    But for $200 can't hurt to have it. I do however recommend the outlets nearby anyway. Phone chargers...
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2014
    katy. tx
    80
    Quote Originally Posted by maxjar10 View Post
    can't argue with that quote. good deal.
    Jan 2014
    Southern California
    58
    What kind of coping will you be using? If it's flagstone I'm sure you can have the pieces cut a little wider on spa to give you the space that you want without messing with shotcrete that's already been put in.
    Mar 2013
    New Hampshire
    351
    We leave our Polaris in most of the time because the ducks think it is a snake and do not land in it. They land in my neighbors and even had ducklings in there a few years ago.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Feb 2016
    Carlsbad, CA
    28
    OK, so they put in the suction side but now I'm wondering if they need to use hydraulic cement around the new pipe. I talked to the PB and he said they would put the pebble/plaster over the hole to seal it but my understanding is the shell needs to be repaired with the cement. Am I right?
    Thanks!
