Results 1 to 7 of 7
Thread: Water leaking from junction box
    fmeaux75's Avatar
    Nov 2015
    Abbeville, Louisiana
    5
    We have a steady drip of water coming from this junction box. Our pool is 3 years old and we have never had this issue before. Also, I am not sure if this is related but our pool lights trip the breaker every time we try turning them on. Any ideas why this is happening? It is a thermocraft junction box.
    20,000 gallon gunite salt water with 5,000 gallon hot tub. Jandy Aquapure 1400 with caretaker system. Sand Filter.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Water leaking from junction box
    Water has gotten into the conduit. Depending on the length of the run there could be a coupler underground that had a leak or there is a creak in the conduit caused by a tree root. Water inside is probably causing the light to trip or I have also seen where the wire nut cracks where the lights wire is connected to the light transformer and then the wire arcs and shuts the light off/trips breaker.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    fmeaux75's Avatar
    Nov 2015
    5
    We opened the top of the junction box and water is just pouring out of one of the lines. I have no idea what to do next about this.
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    Did your part of LA flood earlier this year? If so this conduit may have taken on some water at the junction box.
    IG Vinyl 18x36 28500 Gallon SWG Taylor K2006 Test Kit
    380 Gallon Master Spa Chlorine for sanitizer
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Well you could kill all the power and try to wet vac the water out.
    Paul
    fmeaux75's Avatar
    Nov 2015
    5
    No we did not flood, we had alot of rain but none of it was standing water it all drained away fast. We will try the wet vac this weekend, thanks for the help!
    Apr 2016
    South East USA
    78
    is the junction box at least either 4 in. above the ground or deck, or at least 8 in. above the maximum water level, whichever is greater?
    That is the NEC code requirement.
    If not, water could be entering the conduit from your niche and overflowing at the junction box.
    Otherwise, as others have said it is likely rainwater entering somehow.
    Which line is the water coming from... one that does to light or the panel?
    ft.
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
