Results 1 to 8 of 8
Thread: Pool store says one thing, what say ye?
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    Cool Pool store says one thing, what say ye?
    After I got used to old Intex pool, it was taken out by tornado. I again am a newbie (will clean up sig file soon)
    Pool is almost full, and PB says put 1 bottle (32oz) All Clear stain and scale and run pump for 24 hrs. The bottle says 15oz per 10k gallons. My pool is barely 7700 gal. Should I follow pool store advice, what the bottle says, or other? Pool water is almost to skimmer so I need to be prepared.
    Thanks in advance and Happy Summer!!!
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool store says one thing, what say ye?
    That product is a chelation agent meant to trap iron or copper ions. Do you have metals in your fill water?
    Isolated Spa - 345 Gallons
    Jun 2014
    15,027
    Is there any reason to believe you have metals in the water? If not, I'd say no. Fresh water needs the following:
    - CYA increase (granular stabilizer); for your SWG, I'd suggest an initial target of 70
    - Add regular bleach for a day 1 target of 2-3 ppm; after the stabilizer has dissolved, use bleach or adjust your SWG to maintain FC at 4-6
    - Adjust pH to about 7.6
    - Check TA. If it's high, like over 120, you might want to lower over time to help keep pH stable
    That's about it for now.
    May 2015
    La Porte, TX
    104
    Probably so. We have very hard water here and don't have a softener.
    Quote Originally Posted by JVTrain View Post
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Newpoolcrazy View Post
    Is the water from a well or a municipal/city water supply? Well water can have problems with metals but city water usually has none or VERY little. Did the PB give you a test result that said you had metals in the fill water? Not useful if there was no testing to confirm metals. Hard water means high CH, maybe TA but not necessarily metals content.
    As Pat said, you need stabilizer, bleach and likely some muriatic acid on hand to maintain pH. Only use that product if you have evidence of metals.
    May 2015
    La Porte, TX
    104
    I'll check further about metals. I probably have a water breakdown from the city somewhere. I know it's super hard and has tons of chlorine in it, but that's all I know off hand.
    The rest of your post, I actually understood and know how to do! At least my brain hasn't atrophied yet. Thanks so much!
    Quote Originally Posted by Texas Splash View Post
    Mod Squad pooldv's Avatar
    DFW, TX
    24,459
    If you didn't have problems with metal staining in your old pool I wouldn't add it.
    May 2015
    La Porte, TX
    104
    Thanks, guys! I think I'm going to skip it and go straight to getting the CYA/FC up. Just wasn't sure as this is a different type pool and much more expensive than the old one was.
