Thread: Trying to keep piping simple with pump
    Kannapolis, NC
    89
    OK, I had a PacFab Challenger and decided to buy a superpump. And as my life goes nothing is easy, but I will survive. My delima and I will probably get laughed at but, my Superpump is shorter to the ground as far as piping goes. What I am trying to do is sit the pump on something that will be sturdy enough, I need about and inch in height.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    22,553
    Re: Trying to keep piping simple with pump
    If your pump is sitting directly on the concrete pad you can use a paver or a piece of treated board to raise it up to the level of the piping.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    1 inch paver from lowes should work perfect for what you need I would get the 18x18 to give a nice sized footing for the pump..
