Thread: Water Pressure issues
    May 2016
    Fernandina Beach
    4
    Hi,
    I am new to this forum, so please be patient with me My husband died a few years ago and I am learning to take care of the pool slowly...
    Several days ago I noticed that the fountain in my spa(connected & spills into the pool) was lower after running the pump all day.
    I had the pool maintenance company clean the filter, but that did not seem to have any impact. Yesterday a technician came to inspect
    it, and "sealed" one suspected leak. After he left the same thing happened. I notice air in the strainer basket (it has been cleaned) and
    the pressure drops slowly over 8 hours. He alerted me that I may need a new PUMP. The pump motor was just replaced in Sept 2015.
    (The prior one only lasted 2 years). Is there something else I should ask them to check first? I don't want to rush into any replacements
    just yet. Thanks for any advice
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Water Pressure issues
    Welcome to TFP, sorry for your loss..
    If air is getting into your pump basket you have a pressure side leak, they are the hardest type of leak to find unfortunately, but it can be done
    Check out this webpage and see if you can find it Pool School - Suction Side Air Leaks
    here is a link of pool equipment pictures.. Pool School - Visual Encyclopedia of Pool Equipment
    If you have any more questions please let us know
    May 2016
    Fernandina Beach
    4
    Thank you so much for your quick response. I will try pouring some water over the lid once the pump starts up this morning.
    It is raining here right now, so hopefully I will be able to get to some of the items later.
