Thread: Upgrading AG Pool - Automation, Hardplumbing, and Stenner
    I purchased and had my pool installed last summer with just the basics and manually adding chlorine and plugging in the pump to an extension cord. Fast forward to this Spring... I have added an Intermatic time PE1353ME (I think) and have it ready to program my pump to run as soon as I get finished hard plumbing! I know I am running late a and haven't opened yet, but just had one little thing the installer needed to fix. Anyway, here is where I currently am in the process of hard plumbing. None of this has been glued yet, just want to get it mapped out. I plan to use Jandy Never Lube valves to be able to service equipment if needed. One of the things I am most excited about is adding a fountain already plumbed in! I will also be adding in a Stenner pump, so no more manual chlorine additions! Hopefully I will be up and running by this weekend! I plan to follow up as I go.
    My pool: Sharkline Venture 24' x 52" ; Pentair Dynamo 1 HP 2 Speed Pump ; Pentair SD80 Sand Filter; TF-100 Test Kit w/ Speed Stir
    22,553
    Re: Upgrading AG Pool - Automation, Hardplumbing, and Stenner
    Looks good except for one thing! I think that tape measure is turned around!
    So I got a bit more plumbed and plan to glue it all together tomorrow with my Dad.
    I was itching to take the cover off, so that's what I did. Yanked it off myself. I was expecting to see a green pool. I had broke my wrist right before Labor Day and just didn't take very good care of it after that. When the pool company closed it, I could see algae starting. To my surprise, it was clear until I dropped leaves from the cover in! Already raked most of them out. Plan to throw the pool robot in tomorrow too!
