Thread: No Multiport valve - can I do this on my own?
    May 2016
    Freehold
    27
    Pool was built with only a black thing to open filter and close. There is no multiport valve. I can't empty to waste or anything.
    Jandy DEV60 DE filter.
    Would installing a multiport valve be a DIY project for a basic person? Is it worth it?
    If not what multiport valve would you reccomend and how much should it cost to get installed or how long by a professional?
    Thanks so much.
    Freehold, NJ 22x44 36k gal gunite , SALT system Nature 2 Fusion Soft (NO mineral cartridge), Jandy LXi gas heater, Jandy DEV60 DE filter, 2HP pump, Jandy LED lights (GARBAGE little use in 3 years BROKEN), Polaris 280 pool vac, Meyco mesh (too windy for solid), separate hot tub--Grandee Vista by Hot Springs w/ ACE salt system! Wish I never bought a pool most days but some days, I do finally relax! I do appreciate the help! K2006 & strips
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,418
    Re: No Multiport valve - can I do this on my own?
    Jandy makes a multi-port valve, so it shouldn't be hard to find one compatible with the filter. Replacing the valve is usually not too difficult. It mostly depends on how your plumbing is laid out.
    Love TFP? Become a
    TFP Supporter!
