Thread: Question on Free Chlorine.
    May 2016
    Gahanna
    2
    Was inputting numbers on the pool math calculator. My CYA is 0, but something happened and it defaulted to 70. So slamming my pool it said I needed to take FC to 28. I added the 7 gallons of bleach, and then an hour later I figured It out. At 0 CYA, only need 10 FC to get to shock level. Will this mess anything up? Retested and FC is at 25 now.
    20,500 gallon inground vinyl pool. 16x32 oval
    Pentair Intellichlor IC40
    Taglus Sand filter
    Hayward Super Pump VS
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Question on Free Chlorine.
    Quote Originally Posted by Martyg14 View Post
    Was inputting numbers on the pool math calculator. My CYA is 0, but something happened and it defaulted to 7. So slamming my pool it said I needed to take FC to 28. I added the 7 gallons of bleach, and then an hour later I figured It out. At 0 CYA, only need 10 FC to get to shock level. Will this mess anything up? Retested and FC is at 25 now.
    Sent from my SM-T320 using Tapatalk
    If you have a vinyl liner, it could bleach it. If your pool is plaster, probably nothing will happen. Take a few minutes to fill out your signature, okay?
    May 2016
    Gahanna
    2
    Thanks Richard, liner is old and faded anyway. I updated signature. The liner came out of the track over last winter and did it again this winter. Luckily it's in the shallow end. Needed to drain the shallow end to get it back in last spring. Will need to do the same thing this spring. I just hate to replace it until I absolutely have to. No leaks and hopefully no tears after I refill it again.
    Taglus Sand filter
