Thread: New skimmer box and plumbing help
    Apr 2016
    Lewisville
    5
    I had to purchase a new skimmer box because the old one that came with the pool got crushed when I upgraded to a 3000 gph sand filter pump while vacuuming!
    I needed to add a valve between the box and the new pump since the old 1000 gph pump attached to the bottom of the old skimmer box didn't need a valve. So I thought how about also adding a little 1/2 " Technology with a valve off the side to a foot washing station?
    Do you think the setup in the picture will work? I haven't attached the 1/2" pipe because I want to get it threaded so if I want to remove it I can easily.
    I want to install it in the next day or 2, so any advice would be great.
    Pro Series 16 X 48. Intex 3000 gph sand filter pump with intex saltwater water chlorinator Installed in summer of 2014.
    38,524
    Re: New skimmer box and plumbing help
    If the pump is running, you will just suck in air through that 1/2" pipe ... not good.
    Jun 2015
    Stockholm, Sweden
    250
    You wouldn't want the foot wash on the suction side but on the pressure side of the pump.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
