Thread: Will Overflow kill grass & plants
    May 2015
    Land O Lakes, FL
    527
    My PB installed a overflow that opens out into what will be a landscape area and then it will drain off into a low land area and as it drains will pass through the plants and st. augustine grass.
    Will the salt / chlorine water kill the plants and grass?
    If so, I guess I have some work to do to run a drain pipe about 30-40 feet into the low land area.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    38,295
    Re: Will Overflow kill grass & plants
    With the amount of rain you get, very doubtful it will be a problem.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Less likely in FL with all the rain you get, but over time the salt may build up enough to harm the turf/plants, but the Chlorine won't hurt anything at all.
    Essential Links:
