Thread: Worms in the pool
    Sep 2007
    Tinley Park, Illinois
    74
    Re: Worms in the pool
    Me too. I just opened my above-ground pool last weekend and had a ton of worms. However, I did not cover my pool for the winter, so I thought maybe some birds just dropped them in. I have to say that this was the easiest pool opening ever. It took my husband and me less than one hour. Our pool was dirty, but no algae. I tested the pool and it was great. No more dirty scummy winter pool cover to clean!
    24 ft. round Artesian above-ground pool
    54" depth
    15,000 gallons
    Hayward 1.5 HP EC45 DE Filter
    Hayward H150 Gas Heater
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by tj_shopper
    Aha! You decided not to cover?! I really debated that... you were pleased? I think next year I won't either....
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I posted this over in another thread, but this morning I had to hurriedly get up and rig up a hose to drain water out of my pool due to the torrential rainfall we had last night/early this morning. I was out watching the water level drop, when what to my wandering eyes did appear, but earthworms climbing UP the outside wall of my pool! The walls were wet, and those worms were just inching their way up, pretty as you please. I never would have thunk it if I hadn't seen it with my own peepers!
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Sep 2007
    74
    Quote Originally Posted by frustratedpoolmom
    Yes, it was one of the best decisions we ever made. If you recall, we have this deck going all around our pool and we get so much wind that we have to use sand bags to hold down the winter cover. Both my husband and I are exhausted hauling up all those sand bags, then cleaning the pool cover. This year, all we had to do was keep an eye on the stuff that gets blown into the pool and scoop it out with the leaf net. When we were ready to open, we just hooked everything up, vacuum and we were finished. We will definitely do it again.
    54" depth
    15,000 gallons
    11,969
    Yes, I remember your pool - and we are neighbors of sorts, I'm in Homer Glen on the other side of Orland...so when I saw your post, I thought to myself, well heck, maybe I shouldn't bother either... Did your pool freeze solid during the cold spells? What about one of those air pillows, even without a cover, did you use one of those?
    When the water wasn't frozen, did you add any bleach and/or circulate the water at all? I'm so curious about this....
    Sep 2007
    74
    Hi Neighbor! Yes, it did freeze solid. In fact, my youngest daughter wanted to ice skate on it. I told her absolutely NOT!
    We closed our pool like normal: disconnected all the pipes, put everything away, lowered the pool water to below skimmer, put on the skimmer cover and the eye cover for the return jet. We did not use the air pillow. We didn't use anything. The water did get high from time to time due to the rain. When this happened, we put in one of those pumps to pump out the water until it was below skimmer. I think we did this twice, especially this spring when we had so much rain. When it got warmer, we put in the Pool Rover to clean the pool and poured in a gallon of bleach. The Pool Rover kicks up the water and circulates it somewhat, so we figured that would be a great time to put in some bleach. We did this about 3 times this spring. I think that really helped. But, basically that was it.
    54" depth
    15,000 gallons
