Results 1 to 12 of 12
Thread: Swamp battle
    Apr 2016
    easton pa
    5
    Swamp battle
    Hello all I believe this is my first post. I've read at detail what I need to do to clear up my pool that wasn't closed properly last year. I didn't create a signature or anything yet, and I just ordered the right test kit from this website.
    My question is, I am currently backwashing about every two hours as the pressure starts at about 12 and rises to about 22 in two hours. I really want to be able to let the filter run overnight but I am afraid it can't be left unattended for a complete overnight. I have been testing with the Taylor K1004 and this does not give me a CYA reading, but I added a half gallon of muriatic acid earlier this morning after discovering the PH wasn't even registering below 8.something (the tester doesnt show that high. Any suggestions to let my filter keep on filtering?
    38,262
    Re: Swamp battle
    Welcome to TFP!!!
    Do you have a multi-valve on your filter with a recirculate option? That would bypass the filter.
    Remember that a filter will not eliminate the algae. You have a chemistry problem and need to follow the ShockLevelAndMAINTAIN Process once your test kit arrives.
    Fill out that signature so we know what you have.
    Apr 2016
    easton pa
    5
    Re: Swamp battle
    I am not sure. Would multi valve be the handle i move around to switch between backwash and filter?
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Swamp battle
    Hey there Georgem98, nice to have you here with us
    Where is Easton? Please add it to your profile so we'll know the climate of your pool if you ever have questions. Thanks!
    Apr 2016
    easton pa
    5
    Re: Swamp battle
    I promise to work on my signature by this weekend. Easton is in East PA on the border of NJ. I just took some pictures of the filter and it does look like I have a recirculate feature.
    38,262
    Re: Swamp battle
    Quote Originally Posted by Georgem98 View Post
    Maybe ... if you just turn it around to various settings, then yes. If you turn a handle and then pull it up to backwash, then no.
    Ah, just saw your new post. That will keep your water moving. You can add some bleach daily while waiting for the test kit, but no knowing the pool size I hesitate to say how much.
    Apr 2016
    easton pa
    5
    Re: Swamp battle
    Thank you for the quick responses. The pool is such a custom shape, I have no Idea how many gallons it is. My best guess is about 18-20,000 gallons. Without getting into my long story, just yet, I just moved back in and need to re measure the pool to estimate its size. More to folllow, thanks for the help!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Re: Swamp battle
    Multiport Push-pull
    If you have the multiport, recirculate bypasses the filter completely.
    38,262
    Re: Swamp battle
    Well, at that size, a bottle of bleach daily would be fine ... just wanted to make sure it was not just 5k or something
    Apr 2016
    easton pa
    5
    Re: Swamp battle
    Hi, I had to dig this one up. All debris is out after a month of backwashing, scrubbing, vaccumming..... Now for some fine tuning.
    I still need to backwash once every three hours or so, this weekend I'm going to take the filter apart and clean the panels, which I know will help. My question is since I have zero cya, how would you proceed to raise it knowing that i need to backwash so often. Or should I just wait till the weekend till i clean the panels
    fc 9
    cc 1
    ch 300
    ta 70
    ph 7.5
    cya 0!
    Jan 2014
    Buckeye AZ
    807
    Re: Swamp battle
    You can buy liquid conditioner. It is much more expensive, but you should have as few moving parts, chemically, as you can during a SLAM.
    If you start your CYA around 40 and get the proper amount of FC for that, then you backwash, and end up at (say) 30, you should still have the proper FC level for that CYA. But then you have to change your target because the CYA dropped.
    Basically, there's no accounting for frequent testing during a SLAM. Chlorine every 15 minutes until it holds, then less often as needed to stay above your target. If you are backwashing a lot, you will need to test for CYA once a day also. Try to keep the CYA around 30. Liquid conditioner will allow you to keep your SLAM as even as possible.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jan 2012
    7,306
    Re: Swamp battle
    You put the needed amount of granular CYA in a sock or two and hang them either from a broomtick over a return or put the sock into the skimmer and let it dissolve right in to the water. You can speed it up by squooshing it in your hands now and then.
    Hope this helps?
    Yip
