Results 1 to 10 of 10
Thread: Should I be running my pump, 115 or 230?
    Kannapolis, NC
    89
    Just curious, reason I ask switching from Challenger to SuperPump
    Read somewhere that if it a single switch its 115 if it is 2 its 230.
    Heck I dont know.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Should I be running my pump, 115 or 230?
    Not sure I understand the question. If it's working, then it's likely wired right.
    Otherwise, there's no difference and it can run as either as long as the breaker and wires match the load. Uses the same amount of energy.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    38,272
    What is the question?
    Most 2-speed motors are only able to run on 230V. Most 1-speed motors can run on either 115 or 230V.
    Mar 2015
    380
    Sorry, just saw you are considering a change. 115/120 would be a single pole breaker and double pole would be 230/240.
    Scott
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I am not a pump expert, but electricity is my thing. 230 VAC is more efficient than 115 VAC. The pump will consume the same power, yes, but power loss in the conductors from the power source to the pump is equal to IČR (current squared x resistance). At 230 volts, the current will be half as much as at 115 volts, and the resistance of the conductors will be the same. So conductor power loss will be 1/4. Having said that, unless your conductor runs are REALLY long between the wall and pump, you will notice no appreciable difference. No bearing on your use case, probably, but I felt the need to share.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Mar 2015
    380
    You made an error. Resistance of the conductors would not be the same. 115 almost always also would require a higher amperage breaker AND heavier wire, so less resistance.
    115 at 20 amps, or 230 at 15 Amps.
    115 with 12 Awg wire, or 220 at 14
    Add in distance of the run if you want. Still can't be compared "apples to apples" like you stated, and still NO measurable difference in power used unless the run is HUGE!
    Well, unless in practice someone actually chose between 115 and 230 but with the SAME gauge wire.
    Scott
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by NeedMoreSun View Post
    I made a couple, but I edited them out! Old memories are hard to dredge back up, it seems. My answer was based on existing wires. If heavier gauge wire is used, of course you are correct. But thanks for checking my work
    May 2009
    Youngsville NC
    395
    And for the OP - it really doesn't matter - both will supply the same power. 230V will do it with half the amperage ( means you can use smaller wires ). The BIG issue is what is being supplied at the breaker - it's generally easier to stay with what's already there.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Kannapolis, NC
    89
    So its wired and I assume 115, there is no real reason to switch out to 230?
    _________________
    My Pool:
    38,272
    Well like I said before if you want to go to two-speed almost all of the two speed motors are wired for 230 volts
