Thread: Borate and low TA
    jorivesud's Avatar
    Jun 2015
    Ottawa, Canada
    58
    Borate and low TA
    Thinking of going with Borate in my pool.
    Parameters are the following:
    FC: 4
    CC: 0
    pH: 7.5
    CH: 275
    TA: 40
    CYA: 40
    Salt: 3400
    SWG is not on yet, water too cold
    Should I be concerned about my low TA before I add Boric Acid?
    Or is it OK, to have it at 40?
    My Ph kept climbing last year with a TA that was at 60 (got lowered from melted snow).
    I also had CH of 450 last year (again lowered from melted snow).
    I want to go Borate mainly to keep pH at check, and get the optimized sparkling benefit.
    12x20 vinyl liner + fiberglass steps. (6800 Gallons)
    SWCG - Hayward Salt&Swim 3C
    Hayward XStream Cartridge Filter (200 SQ.FT)
    Hayward TriStar VSP
    Raypak heat pump, Taylor K-2006 test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Borate and low TA
    I think I would raise it to 50 and then let the borate fly. I like some borates.
    JoyfulNoise's Avatar
    May 2015
    13,200
    Borates have limited pH buffering capacity for falling pH (increasing acidity) so you need the carbonate portion of your total alkalinity to deal with that. Usually a minimum of 50ppm TA (mostly carbonate alkalinity) and an additional 50ppm borates makes the water pH very stable. I would not drop below 50ppm TA.
    Matt
    jorivesud's Avatar
    Jun 2015
    Ottawa, Canada
    58
    Ok, I will raise TA to 50-60 before adding borate.
    Hayward TriStar VSP
    jorivesud's Avatar
    Jun 2015
    Ottawa, Canada
    58
    Adjusted TA, but also saw my CYA go up again (was added in a sock in front of return 4 days ago)
    Here are my full results now:
    FC: 5
    CC: 0
    pH: 7.4
    CH: 275
    TA: 60
    CYA: 60
    Salt: 3400
    Water Temp: 60
    Will turn on SWG today, now that water has reached 60.
    I seem to be all set for Borate. Or should I wait a little longer?
    Hayward TriStar VSP
    DFW, TX
    24,485
    Go!
