Thread: Jandy RS four conductor control wire...what is it?
    What kind of wire is this? Can I use simple POTS line?
    Owner built 32,000g Diamond Brite IGP with 1,300g spa, Jandy 2.0hp ePump, DEV60 filter, LXi 400k btu NG heater, PS-8 control, QT 1.5hp blower, WaterColors, Liquidator, PoolBlaster, Blue Diamond
    Lehigh Custom Pools
    Oct 2008
    North Port, FL
    21
    Re: Jandy RS four conductor control wire...what is it?
    Yes, you can use that. They used CAT 5 (Ethernet) cable for mine. It is 4 conductor, 24awg cable. Nothing fancy. If it is exposed outside it should be in conduit to protect it from the elements.
    IG, Fiberglass, 2100gals, so far. This will be my 3rd. pool.
    Excellent...I have tons of both...thanks!
    Lehigh Custom Pools
