Thread: Schedule 80 union fitting - Is this it?
    May 2016
    Indianapolis
    2
    I had a pipe to my skimmer shatter over the winter and I'm building a new one. It has what I think is half of a schedule 80 union on one end of it. There are no markings on it at all except a "3" on the nut, which I assume means the nut is 3". It's on 1.5" PVC.
    It attaches to the other side of the union, on my return that then goes underground. I could try and remove the fitting on the underground return, but it's on more than hand tight and I don't want to risk breaking it or the return pipe.
    The two pool stores near me were no help, but I think I found the part I need online. Can anyone confirm that the part in this link attaches to a 1.5" PVC and has a 3" nut? No one seems to list the nut sizes and some googling around can't seem to find an explanation anywhere.
    The new part: Spears 857 Series PVC Pipe Fitting, Union with Viton O-Ring, Schedule 80, 1-1/2 Scientific
    The old fitting(s):
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Schedule 80 union fitting - Is this it?
    That would appear to be the right style of fitting, assuming the threads match up. You might be best served getting one locally at a hardware or HD/Lowes type store so you could try it out and return for another if necessary.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    like Joel suggested, I would compare to one locally if you can. I think the standard thread is NPT tapered, but I ran into a problem on my SWG cell threads. Some use buttress threads. They look like they'll fit until you try to tighten them down. Hope that helps.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    May 2016
    Indianapolis
    2
    Thanks for the advice!
    I hadn't even considered that a local Lowe's/etc would have a schedule 80 fitting. I'll check in on the way home and hit a local plumbing supply house if they don't. I think both pool stores acting confused threw me for a loop and got me thinking it was a weirder connector than it may actually be.
    I appreciate the help!
