Thread: 2 speed motor, highspeed dead but low one works, is this possible?
    Apr 2014
    Sugar Land, Texas, United States
    42
    So I took my pump to Leslie and they said my highspeed is throwing sparks but the low one is working fine, can this be fix or motor needs to be replaced?
    Inground Plaster Pool, Cartridge Filter, Dolphin PRIMALX3, Hayward H400 Heater, Hayward Pump SPX3220X25Z2PE, 17500 Gallons with Spill Over Spa, Non-SWG, Sugar Land (Houston), TX 77478 USA
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: 2 speed motor, highspeed dead but low one works, is this possible?
    Where is it throwing sparks? If it is near the centrifugal switch, the contacts might be corroded. Sometimes, you can clean them and get it to work for a while but eventually, you may need to replace the motor.
    Mark
    Apr 2014
    42
    Quote Originally Posted by mas985 View Post
    I am not sure, this is what Leslie's Pool guy told me. I'll try to clean the area and if the low speed is working, I'll try to buy some as much time as I can before replacing it. Tks.
